What I'm suggesting you do is aim the peak gain of your antenna at Providence, as those are your weakest stations. There will be less gain towards Boston, but that may be Ok, as those are stronger signals to you. The best solution may be pointing between the two cities, biased towards Providence. If you can't get both markets at the same time, then leave the antenna aimed at Boston.
