Old 7-May-2015, 7:09 PM   #10
I have had some success with very weak signals. A few years ago I tried tvfool reports for my location by zip code, address without height, and address at 5 ft height. I also did a recent update with NMs for 5 ft, which is the height of my antenna because it is in the common area, not my controlled area.
Code:
Real       tvfool-zip   tvfool-address  address 5 ft  Update 5 ft 5/7/2015
 CH         dBm  path     dBm  path       dBm  path    NM(dB)  dBm   path
  7 WTPC   -41.9 LOS     -74.0 2Edge    -81.0 2Edge     9.9  -81.0  2Edge
  9 WSKY   -58.1 LOS     -88.2 2Edge    -95.5 2Edge    -4.6  -95.5  2Edge
 11 WGBS   -73.8 LOS     -98.9 2Edge   -114.6 2Edge   -23.8 -114.6  2Edge
 13 WVEC   -38.6 LOS     -71.1 2Edge    -78.0 2Edge    12.8  -78.0  2Edge
 16 WHRO   -32.4 LOS     -62.3 2Edge    -72.2 2Edge    18.6  -72.2  2Edge
 17 WKTD   -50.0 LOS     -87.9 2Edge    -95.4 2Edge    -4.6  -95.4  2Edge
 20 WUND   -93.8 2Edge  -117.9 Tropo   -117.9 Tropo   -27.0 -117.9  Tropo
 22 WRIC   -57.9 LOS     -87.7 2Edge    -94.3 2Edge    -3.5  -94.3  2Edge
 25 WTVR   -60.4 LOS     -90.1 2Edge    -96.5 2Edge    -5.6  -96.5  2Edge
 26 WRLH   -58.5 LOS     -88.5 2Edge    -95.1 2Edge    -4.2  -95.1  2Edge
 29 WVBT   -32.7 LOS     -69.2 2Edge    -77.5 2Edge    10.6  -80.2  2Edge
 31 WAVY   -32.8 LOS     -66.2 2Edge    -75.6 2Edge    15.2  -75.6  2Edge
 33 WTVZ   -33.3 LOS     -63.4 2Edge    -73.2 2Edge    17.6  -73.2  2Edge
 40 WTKR   -33.9 LOS     -64.4 2Edge    -74.0 2Edge    16.9  -74.0  2Edge
 42 WCVE   -62.1 LOS     -92.6 2Edge    -98.7 2Edge    -7.9  -98.7  2Edge
 45 WNLO   -55.3 LOS     -93.4 2Edge   -101.7 2Edge   -10.9 -101.7  2Edge
 46 WPXV   -35.4 LOS     -67.0 2Edge    -76.4 2Edge    14.4  -76.4  2Edge
 50 WGNT   -34.8 LOS     -69.6 1Edge    -79.3 1Edge     8.5  -82.4  1Edge
What prompted me to make some tests, was that I had been asked if there was a way to hunt for and measure channels that had been missed during a tuner scan. If the tuner doesn't pick them up, we don't know why, and what could be done to receive them.
For the first test I connected my CM4221 antenna, which is outside close to ground level, to my Sadelco 719E signal level meter (SLM) with a short coax jumper (SCJ), and took some readings of my channels.
CM4221 > SCJ > 719E SLM
For the second test I added my CM7777 preamp to see if I could read the weak channels.
CM4221 > SCJ > CM7777 > SCJ > CM0747 Power Supply > SCJ> 719E SLM
Code:
Real      Test 1          Test 2      Amp Gain
 RF           Equiv           Equiv
 CH    dBmV    dBm     dBmV    dBm       dB
 16    -6.9   -55.7    +19.0  -29.8     25.9
  9   -10.2   -59.0    +13.1  -35.7     23.3
 31   -12.2   -61.0    +12.1  -36.7     24.3
 33    -9.0   -57.8    +14.8  -34.0     23.8
 40    -9.0   -57.8    +15.1  -33.7     24.1
 46   -19.9   -68.7     +6.2  -42.6     26.1
 50   -22.0   -70.8     +2.9  -45.9     24.9
Amp Gain is the difference between the two tests and
varies because the signal strengths changed between tests.
I was able to measure a few weak ones that don't always show up after a scan with the preamp:
Code:
                                           Signal Strength at Antenna
                                           Terminals before 24 dB Preamp
                                                  dBm
 17     NA      NA     -10    -59        NA       -83
 19     NA      NA     -26    -75        NA       -99
 22     NA      NA     -20    -69        NA       -93
 42     NA      NA     -25    -74        NA       -98
 45     NA      NA      -8    -57        NA       -81
Antenna enclosure on porch for CM4221 and folded dipole for VHF-High in attachments. The signals have to travel through the openings in the decorator blocks on their way to the antenna. Not much attenuation for UHF, but a lot more for VHF. The openings act like a high-pass filter, as their size is related to wavelength.
