			I believe that the antenna is offered with or without a mast as an option. Sadly, RCA does a poor job (IMO) of providing clear and relevant documentation. Still, the 3036 is worth considering if you have a need for a large all channel antenna.
				__________________If the well is dry and you don't see rain on the horizon, you'll need to dig the hole deeper. (If the antenna can't get the job done, an amp won't fix it.)
