7 WKBW / ABC (real channel 38 at 19.7 dB LOS, 162 degrees)
17 WNED / PBS (real channel 43 at 31.6 dB LOS, 163 degrees)
29 WUTV / Fox (real channel 14 at 27.8 dB LOS, 164 degrees)
What direction is your antenna pointed? Does it have LOS towards Buffalo? Not looking through the roof or trees, etc.? As Tower noted above, did you start at 156 degrees on a compass and tweak bit by bit from there? Sometimes you only need to adjust it a few degrees in one direction or the other and then maybe up or down the pole an inch or two.
