Old 25-Apr-2015, 11:35 PM   #2
StephanieS
Greetings Hank,
The mohu leaf isn't ideal for your situation. At 5' your signal access to the major affiliates is 2-edge and moderate trending weak. Plus in the bay area you have the need for high-VHF (real channels 7-13). A leaf isn't the best option for either of these scenarios.
Is 5' and indoors the only choice you have? If you have the option to mount outdoors I might as a first test install an Antennas Direct Clearstream 2V-J3 and orientate towards magnetic 190 (SSW).
As for your Samsung resetting, hopefully someone reading has a solution. My Samsung 40" hasn't ever had that issue.
Cheers.
