Old 21-Apr-2015, 1:36 PM   #2
StephanieS
Greetings Panduck,
Apologies that no one got back to you. I'll do my best to sum up your situation as I see it. In short, it's challenging. You've got Columbus and Montgomery in there and both are extremely weak.
You are on the right track with the Y10713. For VHF, it'll be your go to. Instead of the 91XG, I would suggest a Antennas Direct DB8e instead.
Before I get any deeper in. Would you post additional plots of 50' and 75' for your address? I want to see if there is any signal improvement. Also your original post is block level, if we could get it to your address only, that'd be perfect.
Thanks.
EDIT: I took the liberty of doing a city level TVfool plot at 75'. The good news is that signal access improves. The bad news is you will possibly need to go UP.
Early possibility for full affiliate coverage:
DB8E
Magnetic 230: WAKA (CBS), WNCF (ABC), WAIQ (PBS)
Magnetic 205: WCOV (FOX)
Y10713
Magnetic 205: WSFA (NBC)
Others may come in, but my goal is to concentrate on full set of reliable major signals.
