Not only are indoor antennas going to have roughly half of their signal blocked, but they may also be too low to "see" a reliable signal.
Electronic devices and people moving around, will also degrade the signal quality.
At very least, you should experiment w/ different antenna locations.
Don't bee too disappointed, if you need to place the antenna outside.
If you're using an amp, it may also be overloading.
