					Originally Posted by ADTech  You don't need an amplifier, they won;t magically correct other errors or oversights.  You need a larger antenna outside, up in the air with a clear signal path, and correctly aimed to have a better shot at picking up those weak or off-axis signals.  Currently, you have a medium/small antenna indoors which is incorrectly aimed. |
 Larger antenna outside isn't happening.
How should I aim it?   I'm limited to only south facing windows.
