You don't need an amplifier, they won't magically correct other errors or oversights. You need a larger antenna outside, up in the air with a clear signal path, and correctly aimed to have a better shot at picking up those weak or off-axis signals. Currently, you have a medium/small antenna indoors which is incorrectly aimed.
