Old 5-Mar-2015, 5:13 PM   #10
As I understand it, the CS5 was designed to cover the High-VHF band (real CH-7 through CH-13)... It was found to have some useful UHF capability which is less directional than it's intentional H-VHF performance.
Antennas like theDB2E, DB4E and DB8E are intended to cover the UHF band (real CH-14 and up) only. It's possible that some useable VHF reception may sneak past the strip-line balun... but reliable VHF reception should not be assumed.
The Antennacraft Y5713 and Y10713 are intended to cover just the H-VHF band. I have had spotty success with UHF reception when experimenting, but I would not recommend this type antenna as a multi-band solution.
If you want an antenna that has intentional support of both UHF and H-VHF, consider the Antennacraft HBU series and the Winegard HD7694P. For attic mounting, I'd avoid the Winegard because it is difficult to re-fold... If your attic proves to be a black hole of TV reception, as many are, the Winegard would be difficult to remove from the attic without risk of damage.
