Old 1-Mar-2015, 5:40 PM   #1
Newberg Joe
Best antenna setup?
Hello,
I live approximately 20 miles SW from TV towers located in Portland Oregon. My challenge is the Chehalem Mountain which lies in between my house and the towers. Mountain is maybe better described as large hill which is maybe 1500 ft at highest point. I live in Newberg which sits in valley on other side of mountain. Here's my TV FOOL report:
http://www.tvfool.com/?option=com_wr...f1f0bf4e9a466e
I'm only interested in picking up the main towers to the NE which would be the ABC, NBC, CBS and Fox.
Would go with outdoor setup, but not on roof. Thinking tripod with 5 ft mast.
There appears to be clear view of mountain top at the 38 degrees line of sight.
I have existing Coax cable running through house from Cable setup which I would like to use if possible. I'm guessing 75 ft from antenna to main TV and would have second tv hooked up in bedroom too.
Based on this info, what do you thinks is the best way to go and best antenna type?
Thanks a million!
Newberg Joe
Newberg Joe is offline   Reply With Quote
