Originally Posted by rafulton1944
In my graph all major networks (abc nbc cbs fox. Pbs) are in green. Is it not likely that they would be viewable with a set-top antenna?
Rich
Since TVF doesn't offer filters for calculating signal loss for attics, set tops, or bank vaults, the only option, is to try your preferred location and see if you're satisfied w/ the results. If not, keep trying.
You should probably expect to lose 7-13 db in the attic and even more set top, since it isn't as high.
You may be better off, just mounting it outside and be done w/ it.
