I am using this ant. Not sure if it is the best one to use
It depends. Is it aimed at Ft Myers or at Riverview (TSP stations)? It should be fine for Ft Myers, but would greatly benefit from adding a VHF Kit (
https://www.antennasdirect.com/store/Reflectors.html ) for the TSP stations as a number of those are VHF.
Is it better to split the signal 3 ways at the ant vs using a 2-way and another 2-way down the line?
It depends. It would likely be better to run a single coax down to your distribution point then install a balanced 3-way splitter there, but we don;t know how your cabling is currently laid out.
I also have noticed that one of my tv's that is on the longest run has a problem with Fox,
WHICH Fox station, there are two on your report.
Different tuners have different capabilities for handling semi-impaired signals. Some do okay, some do not as well.
