I just of an AD DB8 but it is 4x4 rather then stacked like the one you are using. I debating on whether i should modify it to be stacked. also, did you play around with whisker lengths? or did you just start off with 10"? the ones that are on it are 6.5", I m wondering if I might need to modify those as well....
