Attics are not antenna friendly. But it's certainly worth a try. I'd run a line of coax from the antenna in the attic to one television and experiment. Be prepared to try a million or so locations in the attic until you find a sweet spot (it it exists). Keep at least 3 feet away from anything metal, have no metal in the line of sight. And if you have concrete, stucco over metal, or anything else metal, don't expect much.
If you were installing outdoors I'd start with an ANT-751 aimed north, and then keep nudging it west to see if you get the stations at 313 degrees. The ones in green are pretty strong, so it's possible.
