Amplifier cutting out/signal loss
Hi gang... My first post. I am hoping someone can help me.
I have a Clearstream 2 antenna. I was running a Channel Master cm0747 to boost the signal (something the installer gave me). It worked brilliantly for the first year, but then failed.
I tried using a few other boosters, but none gave me the same quality and pulled in the same amount of channels as the cm0747.
I did find a replacement cm 0747, and it worked well for a few weeks and then stopped working. I then tried the apa1260315surh power supply, and that worked brilliantly.
But it too is cutting out on a regular basis, for hours or days at a time. But it will start working again randomly.
Anyone have any idea what is happening here? When it works, I get 40 plus channels. When it fails, I get 3.
The antenna is mounted on the chimney, and I have about 65 feet of cable. I have it split 3 ways after the power supply. Thanks!
