The matter isn't whether you want that station, but that you do have to care about it because it will overload most pre-amps.
It must be noted that the plot shows two entries for WHKY. The first one on the list is no longer in operation as they moved to a newer tower on Baker Mountain, 9.2 miles, 207° true from the OP's location.
I would recommend forgoing an amp until such a time as it can be demonstrated that one is actually needed.
