Here are the 6dB Attenuator results:
Channel 3-1 25 dB SNR, 62% signal strength, RS Corrected 0, Rs Uncorrected 0
Channel 3-2 Same as 3-1
Channel 3-3 Same as 3-1 and 3-2
Channel 10-1 29 dB SNR, 72% signal strength, RS Corrected 0, RS Uncorrected 18
Channel 21-1 29dB SNR, 72% signal strength, RS Corrected 0, RS Uncorrected 0
Channel 21-2 Same as 21-1
Channel 21-3 Same as 21-1 and 21-2
Channel 27-1 29dB SNR, 72% signal strength, RS Corrected 0, RS Uncorrected 0
Channel 33-1 25dB SNR, 62% signal strength, RS Corrected 0, RS Uncorrected 90
Channel 33-2 25dB SNR, 62% signal strength, RS Corrected 0, RS Uncorrected 84
Channel 33-3 25dB SNR, 62% signal strength, RS Corrected 0, RS Uncorrected 202
Channel 49-1 25dB SNR, 62% signal strength, RS Corrected 0, RS Uncorrected 0
Channel 49-2 Same as 49-1
Diagnostic readings were taken around 11:30 p.m. on 11-14
Not to compare apples to oranges, but I remembered my Channel Master DVR+ had a signal quality diagnostic so I connected to it on the same TV and got 100% signal quality even on the stations that I got errors on from the Tivo diagnostic. Kind of interesting.
