I must clarify I have NOT had any negative NM channels come in. The channels that I do get are from 10-20NM(dB).
This weekend I will be up there messing with the antenna and installing a more permanent mount as well as cable clasps. When doing this I will attempt to get the negative NM station by holding the antenna above that second higher roofline and rescanning for station. I should be able to post back Sat. evening with my results then.
