Old 18-Sep-2014, 12:11 AM   #7
BrianHawthorne
attic uhf recommendations
You'll need two antennas, VHF aimed at WTNH and a UHF aimed at Hartford. The VHF can be a cheaper Y5-7-13. The UHF in the attic will be harder to predict. A large antenna is more likely to work.
so for in the attic, i understand bigger is better (more gain, as long as it fits), can you give me any recommendations? Would the DB-8 be OK inside, I know the other gentlemen recommended I put it on the roof, but that's out, too high for me. And what coax is needed RG6? and what products do i need to get it to a lightning bar, (other than the bar and ground cable)? Thanks again, BrianH.
BrianHawthorne is offline   Reply With Quote
