The , 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE.
Has a , Swaged End , so the pipes can be put together.
The 10 foot 6 inch length can be cut to shorter length , and has the Swaged End makes it easier to add a pipe later to increase the length.
The Swaged End can be pointed up toward the sky or down toward the ground , makes it easier to add a pipe to make the over all pipe length longer.
The Swaged End is smaller , For installing antennas that have smaller clamp.
TOP RAIL PIPE is galvanized steel , lasts a long time outside exposed to Weather Water.
