help with antenna ohm dropping
ok if this wrong section im sorry mods.
ok so my wiring backgroung is in car audio and in that form we would chain subwoofers and each one u wire in the ohm drops in half.so here my question.if i hook two antennas in parellel on a 300 ohm antenna then the ohm drops to 150 if i add a third in parellel then wouldnt it drop to 75 which i could splice and solder the coax and feed straight to tv elimiating the baulan completely?can anyone chime in on this ?i would use twin lead to hook them together.is this right or even possible?
