I use an inexpensive 5 - 900 MHz 2-way splitter to connect my DB2 antenna, and amplified rabbit ears, to a coaxial cable to my television. After a lot of trial and error, the combination of the two antennas provides the best reception for me. I've seen more expensive 2-way splitters such as 2 Gigahertz, and 5 - 1000 MHz. Would the expensive, higher MHz and Gigahertz, splitters perform any better than the inexpensive 2-way splitter I currently use?
Also, there is one connector on splitters marked "in" and two connectors marked "out." I use the connectors marked "out" for the incoming signals received by my antennas, and the "in" connector for the coaxial cable connected to the television. Is there any difference between the "in" and "out" connectors? I always think I'm using the splitter backwards.
My TVFool Report
http://www.tvfool.com/?option=com_wr...81a38fa40a5571
