Originally Posted by Tower Guy
There should be enough signal with no preamp or distribution amplifier, even on FOX. I'd do as GUM suggests with the process of elimination and then try replacing the CM-3414 with a 4 way splitter.
You would think that. But, I have run tests on the antennas before bypassing the CM3414 and the signal drops dramatically.
