Old 17-Apr-2014, 8:14 AM   #3
The ANT-3036 All channel antenna will work Ok for your reception location , however the build quality is not so good.
A All channel antenna that has better build quality is the , http://www.antennacraft.net.
HD1800 All channel antenna. HD=Heavy Duty.
Install the HD1800 antenna Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , West North West and East North East , East , East South East.
The Main group of Digital Broadcast Tv Stations/Channels are to the West North West.
Aim the HD1800 antenna at about 287 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
Install a , http://www.antennacraft.net.
10G201 preamplifier.
The FM radio interference trap of the preamplifier will be in the , in/on position.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
http://www.ronard.com.
Most likely , KETK Real UHF channel 22 , NBC , and , KLTV Real VHF high band channel 7 , will be received through the back of the antenna.
The other Tv stations to the ~East~ are Very Weak Signal Strength and have , Adjacent Channel and Co-Channel interference issues.
Tv antenna rotation with antenna rotator.
Is Not channel surfing friendly.
Not recording friendly.
And their , Will Be Domestic Issues , about the direction the antenna is aimed.
Last edited by teleview; 17-Apr-2014 at 7:09 PM. Reason: Clarify information and typos.
