The CM3671 antenna and preamplifier can be used for reception of the South group of Tv stations.
Directional Tv antennas such as and not limited to the CM3671 antenna receive the best in the forward direction
A little less at front angles to the antenna
Less at back angles to the antenna
Less at the back of the antenna.
With the CM3671 antenna aimed to the south , that will put the Tv stations to the , West and North East at angles to the antenna.
KAAL , ABC has 2 Tv transmitters , KAAL Real UHF channel 33 at 266 degree magnetic compass direction and KAAL at 50 degree magnetic compass direction.
If KAAL at 266 degree magnetic compass direction is not received well because it is more on the side of the antenna with the antenna aimed to the south , then the other KAAL will be received at the back angle to the antenna.
If all of the Tv Stations in the Green and Yellow reception zones in the directions of West and North East are not received by the CM3671 antenna aimed South , I think the Tv stations will be.
Then a Second antenna can be installed for reception of the Tv stations to the , West and North East.
A Much Smaller antenna will receive Stronger Signal Strength the Tv stations to the West and North East.
Install a ,
http://www.antennacraft.net.
HBU11K antenna aimed at about 50 degree magnetic compass direction.
The HBU11K antenna and coaxes and splitters will be a Separate antenna
system that is not connected to the CM3671 antenna or antenna system.
Coaxes and and splitters of the 2 Separate antenna systems will go to each Tv location.
A Tv Tuner for the HBU11K antenna system will be at each Tv location.
Here are Tuner / Recorders ,
http://www.epvision.com.
