Originally Posted by In the dark
Thanks for the help, no I don't own the RCA amp, it's what you suggested in your first post so I am going to get the CM7778. Do they have them at Wally world? I did want to let you know I pointed the antenna south still at 10' height and no amp and picked up 5.1 and 5.2 in Ames! According to my map that's almost 90 miles! I'm sure our elevation is a big plus.
Then I need to stand corrected. If you are receiving WOI, real CH-5 reliably, you're doing better than expected. Are you able to receive the signals from the NE at the same time?
If not, but you wish to receive both directions, you may want to consider a two antenna system,
http://forum.tvfool.com/showthread.php?t=2882.
An HBU-44 or HBU-55 aimed NE plus the CM-3671 aimed south.
