The ANT751 antenna comes with a J pole type antenna mount.
If using the the J pole mount or the satellite mount , the location of mount and antenna must be at a location that the reception of the Tv transmitters antennas and the ANT751 receiving antenna are not , obstructed , impeded , blocked , by the building.
Aim the ANT751 antenna at about 0 degree magnetic compass direction.
Here is how to aim antennas ,
www.kyes.com/antenna/pointing/pointing.html
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
The Tv/s Must Channel Scan for , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital Tv's will Automatic channel scan for cable Tv channels.
DO NOT channel scan for cable Tv channels.
Go into the Tv Setup Menu and select and scan for , ATSC-Digital Broadcast Tv Stations/Channels.
To Prove reception connect a Continues length of coax to the ANT751 antenna and run the continues length of coax through a open door or window direct to 1 Tv , no couplers , no splitters.
