			Just to confirm.  I see that this particular antenna has 4 reflector panels.  Do each of these need to point 268 degrees by slightly adjusting individually?  or build the array with the 4 panels straight, and then aim the entire antenna?
 Also,
 Does the pre-amp need to be outside?  I assume no considering the need for a power outlet.
