As to the Lava antenna and others similar.
If the antenna looks like a antenna in a Grade B 1950's SiFi movie , Do Not buy it.
The Magic Tv Antenna manufactures and sellers are retiring to a life of luxury.
I do not . manufacture , sell , recommend , and am not a shill , for magic tv antennas.
So I live a simple life of my social security check and retirement check.
The Current Real Tv channels that are being Transmitted and Received in , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your reception location has receivable Tv channels in All 3 channel bands.
The Tvfool Real Channels List Column shows the Real Channels that are Transmitted and Received.
Recommend install a ,
http://www.antennacraft.net.
HD1800 All channel antenna aimed at about 80 degree magnetic compass direction.
Here is how to aim antennas ,
Install a ,
10G201 preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at ,
http://www.amazon.com , or ,
http://www.hollandelectronics.com.
Buy the ronard antenna mounts at ,
http://www.ronard.com , or ,
http://www.ronard.com.
Home Depot has , 10 foot 6 inch lengths of , TOP RAIL , chain link fence PIPE that makes good antenna mast pipe , the price is low about 10 dollars.
You can use the full length of the pipe or cut the pipe shorter.
Guy wires are not required when the full length of pipe is install in a strong and sturdy antenna mount such as the ronard antenna mounts.
Here are some places to buy antennas and and etc. .
http://www.amazon.com.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so buildings and other obstructions including you own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The directions of reception at your location are , East and West North West.
