Our ClearStream 2V should work fine. Mount it where it has a good view of South Mountain. You have a mix of both high HF and UHF stations. If you have metal roofing, radiant barrer insulation, or TechShield shingles, the attic becomes unusable. Clay tile roofs, to lightly lesser extent, are also signal killers.
You do not need nor should you use any amplifiers.
Re: the HOA - Please see
http://www.fcc.gov/mb/facts/otard.html
