Old 5-Mar-2014, 5:13 AM   #5
For reception of as many Tv stations/channels as can be received with your home made UHF antennas.
Aim 1 antenna at about 140 degree magnetic compass direction and the other antenna at about 240 degree magnetic compass direction.
You can -Test Reception- using a reversed splitter to combine the 2 home made antennas.
The cable length from each antenna to the reversed splitter Must Be the same length.
-->The splitter must be.<--
Non Power Passing - Capacitor coupled.
or
Non Power Passing - Micro Strip Line coupled.
These types of splitters have isolation of splitter connections.
Because their is no direct connections of the splitters connection ports inside the splitter.
The isolation type splitters reduce antenna cross talk and signal strength power reduction of one antenna to the other antenna.
Another way to do it is use a Simple A/B Push Button Antenna Switch to change from 1 antenna to the other antenna.
The Tv Must have a , channel add , and or , channel add scan capability.
If the Tv is channel add capable then the channel that is entered in , Must Be the Real Channel that is transmitted and received.
The Tvfool channel list shows the Real Channel in the Real Channel Column.
The (virt) number , virtual number column Is Not a Real Channel , even if the virtual number is the same as the Real Channel.
Or you can aim 1 of your home made antennas , South , and what is received is , what is received.
Last edited by teleview; 12-Mar-2014 at 1:42 AM. Reason: Clarify information and typos.
