Old 13-Feb-2014, 8:02 PM   #5
WPVI transmitting on Real channel 6 , ABC , is a good channel to receive.
And it looks to me that the greatest number of Tv stations and channels is/are to the , West North West.
That being the case , a All channel antenna such as the , www.antennacraft.net , HD1800 antenna is to be recommended and the antenna will be aimed at about 308 degree magnetic compass direction.
And looks to me like , 20 , 30 , feet or so antenna height will be Ok for reception.
Install a , RCA , TVPRAMP1R preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D , HFS-2D , HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
Here are some above the Peak of the Roof antenna mounts.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Last edited by teleview; 14-Feb-2014 at 7:31 AM. Reason: Clarify information and typos.
