Echoing televiews' assessment of the Mohu, I honestly believe the HBU-11 provides greater performance than the M-sky which appears to be nothing more than a dipole enclosed in a plastic housing. The addition of an amplifier adds nothing to the basic antenna performance. If you have a long cable run, an amplifier could be added, as a means to overcoming the loss in the long cable run, but again, an amplifier does not 'pull' signal from the antenna or air.
Given the presence of KJWP, real CH-2, I'd suggest you also consider using an Antennacraft C490 or HD1200.
Reason: WJWP
