radyio:
Yes those low hills will make that much difference.
The following looks complicated , it is not complicated , what it is , is installing 1 antenna and reaching out all the receivable networks , without installing a second antenna or a antenna rotator.
CKCO-DT Real VHF high band channel 13 , CTV , Is Very Strong Signal Strength , and will be received with any antenna aimed in any direction.
At the 35 foot antenna height.
For reception of Digital Broadcast Tv's stations/channels at , 88 degree magnetic compass direction.
CBLT-DT Real UHF channel 20 , CBC.
CICA-DT Real UHF channel 19 , TVO.
CBLFT-D Real UHF channel 25 , French Tv.
And reach out for reception of very weak signal strength Digital Tv stations
CIII-DT Real UHF channel 41 , GTN. Is very weak signal strength.
CJMT-DT Real UHF channel 40 , OMNI 2. Is very weak signal strength.
CITY-DT Real UHF channel 44 , CITY Tv. Is very weak signal strength.
CFMT-DT Real UHF channel 47 , OMNI. Is very weak signal strength.
And at 126 degree magnetic compass direction.
CITS-DT Real UHF channel , 36 , Religion.
CHCH-DT Real UHF channel , 15 , IND.
I recommend a , Antennas Direct , DB8e antenna , at a starting antenna aim direction , aim the DB8e at about 106 degree magnetic compass direction , a in between aim direction , 88 and 126 magnetic compass direction.
Install a Channel Master CM7778 preamplifier.
Recommend Test reception with only 1 Tv connected. No splitters.
At 177 degree magnetic compass direction.
CIII-DT Real UHF channel 17 , GTN.
CICO-DT Real UHF channel 28 TVO.
Are stronger signal strength and will most likely be received by the DB8e antenna.
That leaves , CITY-DT Real UHF channel 31 , at 213 degree magnetic compass direction
--> IF <-- CITY-DT Real UHF channel 44 , is received then no requirement to receive CITY-DT Real UHF channel 31 , that will require a second antenna.
Any way , install the DB8e Up High and see how the reception is.
http://www.ronard.com/Tripods%200703/4712.html.
Use the , 4712-50-10 tripod , it accepts small diameter mast pipe and larger diameter mast pipe up to 2.2 inches.
http://www.saveandreplay.com.
http://www.trentondistributors.com.
http://www.ronard.com.
