Old 18-Nov-2013, 6:44 PM   #27
Linux Script
Here is a script that works well on a basic Linux box. The function is similar to the Windows batch file in post #5, giving you the function of a PVR/DVR. Edit variable values as needed.
Note that this script also adds tuner locking. This prevents another user, script or application from interrupting the tuner while it's recording. The lock key is the recording time stamp variable, so it's not impossible to override the lock if the need arises.
Use "cron" or "at" to launch the script at the correct time.
Code:
#!/bin/bash
#Virtual Channel
VC=5.1
#Real Channel
RCH=48
#Transport Stream Program Number
PROG=3
#Run Time - minutes
RUN_TIME=32
#Recording File Title
TITLE=Test_Recording
#Select Tuner by 'uncommenting' one Tuner
#TUNER=1019D817
#TUNER=101A5A4B
#TUNER=101AE560
TUNER=1032E7DB
#Specify Sub-Tuner, 'tuner0' or 'tuner1'
SUBT=tuner0
#Recording Time Stamp
REC_TS=$(date +"%Y%m%d%H%M")
hdhomerun_config ${TUNER} set /${SUBT}/lockkey ${REC_TS}
hdhomerun_config ${TUNER} key ${REC_TS} set /${SUBT}/channel auto:${RCH}
hdhomerun_config ${TUNER} key ${REC_TS} set /${SUBT}/program ${PROG}
hdhomerun_config ${TUNER} key ${REC_TS} save /${SUBT} /home/tom/Videos/${TITLE}_${REC_TS}.mpg &
HDHR_PID=$!
sleep ${RUN_TIME}m
hdhomerun_config ${TUNER} key ${REC_TS} set /${SUBT}/channel none
hdhomerun_config ${TUNER} key ${REC_TS} set /${SUBT}/lockkey none
kill $HDHR_PID
exit
# Schedule using "at HH:MM MMDDYYYY -f /home/<user_name>/bin/<script_name>
# or use crontab
