Yes, you can do that. The VHF antenna will not be amplified, though, since the Sky's amp is mounted inside the outdoor housing.
Install and aim the VHF antenna so that it works well. If you find that it needs to be amplified, you will need completely separate down-leads and you'll have to install the U/V combiner at the outputs of the respective combiners.
If the VHF antenna is fine as a passive installation, then you can combine the two antennas using either a Radio Shack 15-2586 or our EU-385CF as close to the two antennas as you desire. Do NOT substitute a Holland or TruSpec/PicoMacom (or any other) UVSJ as the two liste above are the only ones known that will pass your pre-amp power THROUGH the UHF side of the device which s what you need.
