Agreed, coax with messenger wire can serve as the grounding conductor for the mast.
You will also want to ground the coax shield, use a grounding block prior to the coax entering the building. A common location for the grounding block is near the existing electrical service were it's a short run to connect to the ground rod.
http://forum.tvfool.com/showthread.php?t=901 (post #20 is a summary)
