The three channels that I mentioned are, realistically, the only channels you may be able to receive according to the information posted in your TV Fool report. I doubt you can get the fourth channel in red (25) because the signal is incredibly weak. Every channel in gray is not likely to come in because these channels are too weak at your location.
Check with some of your neighbors to see if any are using an over the air antenna to receive local TV. Also, drive around a bit to see if you see any in use within a mile or two of your home and perhaps talk to the home owner to see what they get. Pull a TV Fool report for any location that you see a over the air antenna and that might give you some idea of what you might get at your location, if you do and do not talk to the occupant.
