Direction?
I agree with the above poster. Adding an an amplifier would probably just overload the TV's. Since you live in an area with very strong signals, something must be wrong if you're not getting good reception. There are a few things I can think of:
---Have you made sure the antennas are pointed in the right direction?
---Are you using the upper antenna or the lower one? Test them to see which one gets a better signal.
---Maybe your feedlines are very old and suffering from high loss.
---Have you tried an indoor antenna? You'd probably have to use one for each TV, but you could just use on to test how good your reception is.
I hope this list helps you, and good luck with your reception.
