Thread: Amp or ???
Old 5-Oct-2013, 10:23 PM   #4
Install a NEW Matching Transformer (Balun) to each antenna.
To Prove Reception. Install a NEW Continues Length Of Coax to 1 antenna at a time , Do Not connect the 2 antennas on to 1 coax at the same time.
Use New continues length coax that has the Compression type connectors on the ends of the coax , not the old crimp type connectors on the ends of the coax.
Run the New Continues Length of coax through a open window or door direct to 1 Tv.
No splitters , No couplers , No ground block couplers , No etc. .
Aim the antenna at about 270 degree magnetic compass direction.
_____________
Do not use any type or kind of antenna system amplifiers.
_____________
Digital Broadcast Tv Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
Do Double Rescan , http://www.wchstv.com/DoubleReScanAlert.pdf.
______________
What is reception like now??
___________
