Cable should not be acting as an antenna. Cable should only conduct signal from the antenna to the tuner, with no signal leaking in or out along the way. Only the antenna should behave as an antenna.
This continues to make me wonder about the integrity of the connections between the coax and connectors at each end.
However, the ANT-751 is a much smaller antenna than I would specify for your situation. You may simply be receiving too weak a signal to insure reliable reception %100 of the time.
