Old 2-Oct-2013, 4:01 AM   #31
...I know I'm getting to be a bit of a pest here so please bare with me...
I don't think you're a pest.
If the signals are stable/reliable, and you have no need to run more cable, why add an amplifier at all?
If you plan to add more TVs to your system or change the location of your TV so that more cable is needed, then a preamp may be in order.
If you truly need a preamp due to existing or future cable & splitting losses and are going to stick with one antenna, then opt for the PA-18 which is an excellent weak signal amplifier with very good noise specifications.
If you plan on building a two antenna system such as the DB4e and Y10713, then use a TVPRAMP1R.
Based on the combination of the information in your TV Fool report and your on-site reports, should I move in next door, you'd see my DB4e, Y10713 and TVPRAMP1R hoisted proudly up the mast.
