Old 30-Sep-2013, 8:31 PM   #3
KIDU-CD Real UHF channel 17 , has , FOX , MyNetwork , Cozi.
http://www.rabbitears.info/market.ph...ility_id=58557.
KXVA Real UHF channel 15 has , FOX , MyNetwork.
________
KTAB-DT Real UHF channel 24 is , CBS.
KRBC-DT Rreal UHF channel 29 is , NBC.
KTXS-Tv Real UHF channel 20 is , ABC , CW , This Tv.
KAZU Real VHF high band channel 13 is , Religion.
______________
For reception of the Tv stations channels to the , North West and not the Religion channel 13.
______________
Install a Channel Master CM4228HD antenna aimed at about 299 degree magnetic compass direction.
_______________
KTXS is very weak signal strength and KIDU is very strong signal strength.
If KTXS is not received reliably with with no amplifier then try a CM3410 distribution amplifier.
The CM3410 is designed to resist over loading from strong signal strength signals such as KIDU.
_______________
The Winegard DS3000 J pole type antenna mount will work Ok with the CM4228HD antenna.
_______________
