Quad shield is not going to help, the antenna allows desired signal along with whatever interference is in the air into the coax. The extremely small amount of signal or interference that could leak in through the shield of standard coax is already much much less than you need to be concerned with. If the signal meter reading is stable when you wiggle the coax at the connector, it's probably just fine, I've yet to have trouble with any compression style connector. (Crimp connectors are a different story....)
Both the 91XG and PR9032 are designs that covered channels 14 to 69. They both tend to favor the higher channels. If cost is an issue, and you already get K14IU-D with an small indoor antenna, the DB4e would be my choice. It's a newer design, concentrating on real channels 14 to 51, which gives it better performance than older antennas of a similar configuration. The DB4e is also going to have less wind loading.
