Originally Posted by skatingrocker17
I guess now I need to choose between the AntennaCraft 70 (FM6) or the Winegard HD-6000. Also, should I use some sort of amp? I plan on splitting the signal 2 or 3 times and one of the runs will be 100' from the splitter.
Either antenna would be a good choice & will far exceed what you are getting now with the Stacker. The FM 6 is slightly better & can be
easily modified for even better performance. You should run a separate cable from the antenna to the FM tuner(s)
Are you connecting the antenna to 3 FM tuners?
