Thanks for having this forum, it's extremely helpful. I have two questions below, about the HVAC and the amp left by Cox, and would appreciate any further suggestions.
I read through several San Diego area posts and purchased a Winegard 1080 and a Radio Shack FM trap 15-024. Trying to get 8 & 10 (ABC, CBS). Antenna is currently pointed away from the ABC CBS stations with no reception (used a real compass, back of the antenna aimed at 283). All stations east are good.
http://www.tvfool.com/?option=com_wr...46aef3f49ea846
Antenna is approx. 5 feet from (above) an HVAC compressor; would this matter?
Cox left an amp, pctvc2pt, which has been installed on downlead after FM filter, tried it both with and without power, didn't make any difference. Can you tell me if this is the correct type of signal amp?
http://www.pctstore.com/RF_amplifier...p/pctvc2pt.htm
Our next step will be to experiment with the height...
