Old 9-Jul-2013, 9:26 PM   #2
Install a Antenna Craft , C290 antenna in the attic aimed at about 35 degree magnetic compass direction.
____________
A antenna system amplifier will most likely not be required.
____________
___________________________________________________
As a ->Test<->Prove Reception.
Connect a ->NEW<->Continues Length Coax to the matching transformer (balun) of the antenna , and run the NEW Continues Length of Coax direct to 1 Tv.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadscat Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Scan for channels.
http://www.solidsignal.com.
Solidsignal has the C290 antenna for $37.99 .
http://www.amazon.com.
http://www.antennacraft.net.
Last edited by teleview; 11-Jul-2013 at 4:12 PM. Reason: Clarify information and typos.
