It looks as if the reflectors (V shape) are mounted backward or the boom (stem) is.
Here is an example similar to your antenna, a UHF Yagi type antenna with corner reflector: http://www.winegarddirect.com/viewit...P%29&p=HD9075P
In the drawing, the back of the antenna is on the left, attached to a mast. The end closest to the transmitter is on the right side of the drawing.
