92116: What I've learned
JHCB:
I'm close to you (92116) and have two TVs, each with separate antenna:
Winegard HD7698P at 40' above ground with rotor: I get all SD/Tijuana/Tecate stations plus, depending on atmospheric conditions (barometer), (from LA) 2.1-2, 5.1-3, 7.1-3 (if analog KZTC-LP-7 is off the air, which it has been for last couple of weeks; good riddance...since same Fox.Mundo available in digital on 49.2), 11.1-2, 13.1-2, 30.1-4, 58.1-4, and 63.1-8. As a bonus, sometimes, 4.1-2, 24.1-4, 50.1-4, and 52.1-2.
RCA ANT1650R: Our second set, in kitchen, is attached to an RCA "indoor" antenna which we have placed outside under an overhang to avoid the elements, but just four feet off ground...and get all SD/TJ/Tecate except 3.1 (XHTJB), although analog (e.g., 35 UCSD-TV) not really watchable as it is on other set with Winegard. We found that positioning inside was always challenging, with 8.1-2 and 10+ most problematic.
Best wishes!
